Previous in Forum: 3 Phase to Single Phase Voltage Conversion in Stabilizer   Next in Forum: Converting Electrical Power into Mechanical Load/Torque
single phase supply for a three phase ind motor
02/04/2010 12:46 AM
How can I describe a circuit for the above given title
Re: single phase supply for a three phase ind motor
02/04/2010 1:14 AM
Use Inverter/ cycloconverter.
Good Answers: 804
02/04/2010 2:29 AM
Assuming you want to know how to size a single phase supply to feed a phase converter that runs a 3 phase motors, the single phase current will be greater than the 3 phase current by a factor of 1.732 (sq. rt. of 3), plus any losses in the phase converter. Generally, static phase converters are only about 40% efficient when you account for the loss in power of the 3 phase motor due to unbalanced power, rotary are about 70% eff for the same reason. Digital phase converters such as VFDs are about 95% efficient as a group, some claim higher numbers.
If you are thinking you can run a 3 phase motor from a single phase supply without adding a phase, you are mistaken.
Register to Reply 2 comments
