Hi i need your help, I am building a project of charging a mobile battery with solar panels. For this i am using AT89S52 Micro controller. As i want the solar panels to turn around where there is most of the sunlight falling i am using photo resistors. I am using 2 photo resistors each at one end of the solar panel. These photo resistors cant be directly connected to AT89S52 so i am using PIC16F877A where i can use the 2 analog comparators to compare which photo resistor gives the maximum output current. Then this value is passed from the PIC16F877A to AT89S52.Is this correct??
I was also thinking that i could add a gps and a signal booster to this project and make it as 1 complete kit.
And i would really appreciate if you can guide me how to go ahead with this project as i don't have any idea about the circuit diagrams and components to be used.
With Regards,Thank you.
