Previous in Forum: York Marine Chillers   Next in Forum: Fence Mesh to Guard Cooling Tower Fans
Static Pressure
02/05/2010 5:45 AM
how to measure static pressure@how to get static pressure?
Good Answers: 53
Re: static pressure
02/05/2010 6:30 AM
Good Answers: 137
Re: static pressure
02/05/2010 9:33 AM
You simply use a branch connection on the pipe wall (perpendicular to the wall) and fit a manometer or pressure gauge of the appropriate range. You need to have some idea beforehand of what the pressure will be to select the right pressure range.
Cheers.........Codey
Good Answers: 29
Re: static pressure
02/05/2010 10:18 AM
You can compute static head by multiplying the height of the liquid in the system (Hft ) by the weight of a one foot tall one inch column (Wlbs/ft) of the liquid.
Head Pressure = Hft X Wlbs/ft
For water Wlbs/ft = 0.433
Therefore; A 25 foot tall volume of water has a weight in pounds per square inch (PSI) of:
25 X 0.433 = 10.824 PSI
Si vis pacem, para bellum
Re: static pressure
02/05/2010 4:16 PM
with the pitot tube..., but you should specify your case.
Register to Reply 4 comments
Codemaster (1); gustavoququ (1); PMoon (1); rakesh_semwal (1)
