Previous in Forum: Fence Mesh to Guard Cooling Tower Fans   Next in Forum: Hyd motor equivalent to Rexroth A6vm
Open Channel Flow Measurement
02/05/2010 11:06 AM
I need to measure the flow in an open channel 15ft wide, 13 ft deep, several hundred ft long. (Chlorine Contact Tank, water is pretty clean)
The channel has a weir, but is not straight, more of a "L" shape, therefore using a regular ultrasonic level meter poses the problem of establishing proportionality between level and flow.
I am looking into the Area Flowmeters and Velocity Profiling with pulse doppler technology;
anybody out there who has experience with these different technologies?
Pathfinder Tags: flow meaurement flow meter
Good Answers: 29
Re: open channel flow measurement
02/05/2010 12:09 PM
Re: Open Channel Flow Measurement
02/06/2010 7:20 PM
Check out this link.Use a parxhall flume, and altrasonic level sensor.The ratio of height to flow is 5/3 power if sensor is installed where recommended.
http://www.plasti-fab.com/wastewater-products/parshall-flumes
HTRN
Register to Reply 2 comments
