Previous in Forum: TNC Switch for ACBs   Next in Forum: Resistance value of 10HP , 3 phase , 415v , 50hz , induction motor
omnipure 12 high temp alarm wont reset?
02/05/2010 7:52 PM
we have a high temp alarm on the control panel, it will not reset. Relay cr37 opens and closes very quickly on depressing reset. The cells look ok, clean and in good condition, ive shorted out the temp s/w but it still comes on when 3 pos s/w is turned either way to auto or hand??
Just after this happened i isolated the supply, checked the relays are all ok, 4.5kohm approx on each, checked connections etc. On restoring power and turning to hand the F5 fuse blows?? different symptom now.
Any ideas appreciated.
Pathfinder Tags: marine offshore
Re: omnipure 12 high temp alarm wont reset?
02/07/2010 12:46 PM
what do you mean by (shorted out the temp switch)?
