Previous in Forum: Small Hydraulic Systems   Next in Forum: Natural Gas Consumption - CAT Generator
8 comments
Basket Strainers
02/07/2010 1:55 PM
i need to make basket strainer in the shape of cube. the strainer will be made of fine screen and have socket connection to a pipe.
please advice on how to make the drawing.
Re: basket strainer
02/07/2010 4:13 PM
Will you be making the strainer yourself, or the drawing of the strainer yourself, or neither, or both?
Do you have CAD system?
Re: basket strainer
02/07/2010 11:09 PM
See the following site: Image results for cone strainer.
Re: basket strainer
02/07/2010 11:55 PM
"need to make basket strainer in the shape of cube".
Most strainers are of cylindrical or conical shape for the obvious reason that cylinder and cone can stand for greater hoop stress/circumferential stress compared to cube/cuboid. That is the reason storage tanks are mostly cylinerical.
In case of strainers, the debries are preferablly collected inside for maintenance reasons. If strainer gets blocked, a cylinderical/conical strainer would retain the shape well compared to to cubical one.
So, why cube shapped strainer?
Re: basket strainer
02/07/2010 11:58 PM
Re: basket strainer
02/08/2010 10:09 AM
"So, why cube shapped strainer?"
this strainer will be used inside sewage water tank, for that reason i would like to get max mesh area so it will not clogged fast. the mesh size i want to use is very fine mesh.
the cube strainer will be open from one side to cover the inlet sewage line and only filtered water can go to the tank.
Re: Basket Strainers
02/08/2010 6:19 PM
Can you specify the mesh material and size of mesh? Can you specify the other materials of construction? Can you describe the part and all the pieces it would take to make it?
02/09/2010 9:57 AM
since i have not gone through the details of designing the strainer
i will appreciate if you have answers to the questions you have raised
02/09/2010 10:35 AM
No, I don't have answers. You need to have at least an inkling of what is going on.
I'm done.
Goodbye.
Abdel Halim Galala (1); Anonymous Poster (3); lyn (3); yesyen (1)
