Previous in Forum: Electric Car   Next in Forum: Bike Shows: Beauty in the Eye of the Beholder
1991 Geo Tracker - Stuck Choke Valve
02/08/2010 9:06 AM
I have a 1991 Geo Tracker. This cold weather has the choke valve in a stuck position. The engine sounds as if it is idle very high. Where do I find the choke valve and how do I make the adjustment please?.. Thank you Naynay..
Pathfinder Tags: choke Idle
Re: Geo Tracker Choke Valve
02/08/2010 2:13 PM
The 91 geo trackers used a throttle body fuel injection system. Thats why you cant find a choke valve. Most likely you have one or more engine sensors and or control devices that are bad.
Good Answers: 123
Re: 1991 Geo Tracker - Stuck Choke Valve
02/08/2010 10:42 PM
When the engine is operating in cold weather, it needs a richer mixture, and a higher speed to prevent stalling.
If your temperature sensor is bad, or if your thermostat is bad, or has been removed, the engine will stay in the cold/rich/fast mode. I hope this helps. Good luck.
Bob
02/09/2010 8:18 AM
Check for a possibly stuck IAC (Idle Air Control) valve problem. Most service manuals will describe how to check the IAC valve.
Register to Reply 3 comments
Anonymous Poster (1); bob c (1); tcmtech (1)
