Previous in Forum: NPFA 72 - Smoke or Heat Detectors in Generator Rooms   Next in Forum: Stabilizing Waste Sediment
Pneumatic Tools vs. Hydraulic Tools
02/08/2010 6:17 PM
whats the difference between a pneumatic and a hydraulic tool
Good Answers: 143
Re: power tools
02/09/2010 7:52 AM
Is this a trick question?
Air versus oil.
Re: power tools
02/09/2010 8:29 AM
Can you compress air?
Can you compress oil?
CARPE CRUSTULORUM!
Re: power tools
02/09/2010 9:03 AM
Usually the pneumatic tools are impact type, the hydraulic are non-impact.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
Re: Pneumatic Tools vs. Hydraulic Tools
02/10/2010 12:41 PM
If you're referring to pneumatic or hydraulic torque tools, either can be "non-impact". Pneumatic torque wrenches exist whereby the output torque is controlled by the input air pressure.
Pneumatic torque wrenches are continuous-rotating whereas hydraulic torque wrenches are, for the most part, ratcheting.
A hydraulic torque wrench delivers much higher torque output than a pneumatic torque wrench of similar size and weight.
Hydraulic torque wrenches require an external hydraulic pump while pneumatic torque wrenches can be operated by simply plugging in to a properly conditioned plant air supply.
Hydraulic torque wrenches are much more robust and forgiving than pneumatic torque wrenches.
Best regards, HeviiGuy
05/28/2011 1:28 PM
BoltIntegrity
What does it mean when you say more "forgiving"?
I want to consider the construction of the backhoe loader's "arm". In such a case, what differences (advantages and disadvantages) would exist in using pneumatic pistons in place of hydraulic pistons? I want to create a model of such a thing, using pneumatic pistons instead of the actual hydraulic pistons. I am not a mechanical engineer. If anyone can put this to me simple, I would appreciate it. I understand the basic principle of pneumatic/hydraulic systems which multiply the force by trading them for distance moved - much like other "simple machines".
Anonymous Poster (1); BoltIntegrity (1); Jay_ (1); not so smart (1); TVP45 (1)
