Previous in Forum: Class X Current Transformers   Next in Forum: Power Lines
How to Control Transformer Loss
02/10/2010 6:02 AM
our factory transformer idely consume 3 kw consume per hr 3 unit .how to minimize the losses.
Re: how to control transformer loss
02/10/2010 8:40 AM
What is the rating of the transformer?
Any transformer will have its efficiency (and hence the no load losses).
If it is abnormal, change the transformer.
If it is normal, switch off the incoming feeder when idle.
02/13/2010 4:48 AM
transformer Rating :11kv/440v,500kva,delta/star conn.
which side current transformer connect?
Ht structure to transfomer cable distance 100 mtrs.cable rating 185 Sqm.xlpe.
how to minimize cable loss?
02/13/2010 7:33 AM
For a 500KVA transformer a 3KW loss looks to be very good.
The input current is only about 26A
for 185sqmm (sqm ) XLPE cable, your resistance is about 0.17 Ω/km ie for your ampereage the total loss in cable will be about 35W
You are well within all normal practices (unless I have miscalculated something) including the 3KW.
Where is actually the problem? Amd I missing something?
02/10/2010 11:19 AM
Dear Sir
1)As asked by one of the participant ,let us knw the rating of the transformer.
2)The losses of the transformers and their prices are linked.Higher the loss, lower is the price.At the time of procurement itself ,it needs to be taken care.
regards
Register to Reply 4 comments
Anonymous Poster (2); ravipra01 (1); saransat1981 (1)
