Previous in Forum: Mobile Test Kit for Electrical Cables   Next in Forum: Transformer Oil Break Down Voltage (BDV)
Calculating Stator Slot Depth
02/11/2010 7:02 AM
I need the stator slot depth to get the outer diameter of stator core. How do we calculate the stator slot depth?? I would appreciate if someone could help.
"If opportunity doesnot knock, build a door."
Re: Calculating Stator Slot Depth
02/12/2010 8:40 PM
I am speaking out of my usual field, I wonder how there can be a given ratio of slot depth to outer diameter of generator? stators.
The slots are formed by the laminated punchings that form the stator core. The slot depth is calculated to accept the stator bars, filler pieces, insulating materials and slot wedges. The stator bars can be any thing from solid copper to hollow strands for water cooling. The insulation will vary as to the heat capability of the different insulating materials. Filler pieces may or may not be required. Slot wedges can be different sizes and materials.
I really don't see how you can calculate the outer diameter of the punchings or the depth of the slot without knowing all these things.
Of course I have been wrong before.
If you fail to follow through, you will fail.
02/16/2010 10:10 PM
Hi Otha, thanks for the inputs.
Yeah, lots of things seem to inter-related. It is bit complex.
Register to Reply 2 comments
