Previous in Forum: Measurement Methods for Flatness   Next in Forum: Screw Type Compressor
Spiral Walls vs. Straight Walls in Thermal Powerplants
02/18/2010 1:41 AM
Dear Sir,
i want to know what is the advantage of using spiral walls instead of straight walls in thermal powerplant
Re: spiral wall
02/18/2010 3:48 AM
generally spiral water walls used in once through boilers...because water is exposed with heat source more time...
Re: spiral wall
02/18/2010 3:54 AM
can you provide any additional information.
Re: spiral wall
02/18/2010 8:29 AM
I could give you the answer but first I need to know if this is a school assignment.
CARPE CRUSTULORUM!
Re: spiral wall
02/18/2010 9:56 AM
yes sir, iam working in a 660MW Thermal power plant (super critical boiler) as a trainee. I want to know deeply about thermal power plant construction and design aspects etc. Pls help me sir.
Re: spiral wall
02/18/2010 12:02 PM
Ok. The simple answer is this:
Have you ever watched how the ocean hits the beach? It rolls in on waves. Water runs in spirals as does air. If you open an old air duct you will find that there will be dust,dirt and debris in the corners and a round(ish) hole in the middle. This is where the air flows with least resistance. Water flows the same way. in a square pipe you will have resistance. A round pipe will flow better and a spiral pipe,where the spiral flows with the turn of the water, will allow the flow of water with the least resistance.
There are a lot of numbers and theory behind it but this'll get you started.
Good luck.
CARPE CRUSTULORUM!
Good Answers: 58
Re: Spiral Walls vs. Straight Walls in Thermal Powerplants
02/18/2010 10:34 PM
Fluid dynamics is an interesting subject. As a fluid (or air) is forced around a turn, it rotates. In a river, water that was on top goes to the bottom, and water from down below is brought up. As water goes down a drain, it spins. In order to go down the drain, it had to go around a corner, so spin is applied.
mike k
Register to Reply 6 comments
Anonymous Poster (1); mike k (1); not so smart (2); venkatesh047 (2)
