Previous in Forum: Gravity Flow Hydraulics   Next in Forum: What Causes the Axial Movement of a Shaft in a Gearbox?
Fan Configuration Debate
02/18/2010 2:45 PM
just wondering which fan configuration would produce more volume and pressure when rotating at approx. 3200 rpm.
The fan blade is 8" in dia. with a 4.5" dia. intake hole
Good Answers: 58
Re: Fan Configuration Debate
02/18/2010 10:00 PM
I favor the curved blades, they would have less eddies and cavitation, a more laminar flow than the flat blades. Note the scimitar blades on modern prop planes.
mike k
02/19/2010 1:29 AM
3200 RPM is pretty fast for an inexpensive 8" fan. are you sure the squirrel cage (either configuration) can handle that speed?
Good Answers: 27
02/20/2010 4:14 AM
Comparing backswept and radial blading.
Some general comments based on fixed tip speed for both designs;
Radial
  • Higher input power required
  • stress conditions are better (all points on the blade are on a radial line, so can be used at higher speeds).
  • Ease of manufacture
  • Usually cheaper
  • Less efficient
  • Develop higher head than back-swept
  • Unstable head capacity curve at lower flows (flat in usable range)
  • Head curve tends to be steep - drops off fast at high flow.
  • Best efficiency is usually close to surge line
Backswept
  • Lower input power requirement
  • worse stress condition
  • lower head than radial
  • more expensive construction
  • larger stable operating range
  • best efficiency is within the safe operating range (away from surge).
In other words, use back swept vanes if the cost is justified.
I have no special talent. I am only passionately curious. Albert E
02/21/2010 1:17 PM
thanks for the input ,i was hoping that the back-swept type would be better, i was just concerned i may lose some of my pressure[1.25" of Hg.]that the straight blade radial fan produces for me now
marc
Good Answers: 27
02/22/2010 4:14 AM
You will develop a slightly lower head with backswept as compared to radial vanes. (As stated in previous post). I do not know the shape of the fan casing but if you are using a different geometry impeller in the same casing you may also loose some head.
dkwarner (1); fun in the snow (1); Kaisan (2); mike k (1)
