Previous in Forum: Silvering and Making Nickel Plate   Next in Forum: Role of a Chemical Engineer
Microstructural Differences in Aluminum Tube
01/30/2007 4:47 PM
Is there a difference in microstructure between extruded and drawn aluminum tube? I know the the microstructure will be elongated in both unless artificially aged? Are there other specific differences? Will I be able to differentiate by mounting, polishing, etching and examining with an optical or electron microscope?
ONE TEST IS WORTH A THOUSAND EXPERT OPINIONS
Pathfinder Tags: metallurgical
Re: Microstructural Differences in Aluminum Tube
01/31/2007 1:05 PM
If annealed after draw or extrusion, the aluminum latice structure will return to "normal". Quenching can be done to harden if you like.
