Previous in Forum: Vibration Dampening   Next in Forum: L Angle Weight Calculation Formula
Volume Flowrate of Air in a Pipe
02/23/2010 4:16 AM
How can we determine volume flowrate of air in a pipe?
we have simple equation
Q = Av
but how can air velocity be determined in the pipe
i got air velocity equation i.e.
v = Sqareroot(2500 DP/L)
while D = inner Dia of pipe
P= Pressure Drop in the pipe due to friction
L = Length of pipe
is this equation correct
Please suggest me any solution
Re: Volume flowrate of air in a Pipe
02/23/2010 4:55 AM
Hai, Names Rajah and I'm a Service and Project Engineer in a air compressor line. Your request on the question will be CFM, is it?
02/23/2010 11:15 PM
Yes U can Cosinder CFM or Cubic meter per sec
Actually i want volume flowrate of air in a pipe
Good Answers: 101
Re: Volume Flowrate of Air in a Pipe
02/23/2010 9:12 AM
Velocity of air x cross-sectional area of pipe = volumetric flow rate of air.
Good Answers: 137
02/24/2010 11:20 AM
Impossible to say whether your equation for flow vs presure drop might be correct unless you give the units for all the quantities, and say whether flow/velocity is at actual conditions or (stated) standard conditiions.
But if you're talking about compressed air (7 barg/100 psig-ish) it's wrong, needs to include pressure and temperature of the flowing air.
If you mean ventilation air, where pressure is close to atmospheric, it could be correct.
Cheers.........Codey
02/24/2010 3:11 PM
As you know there is no flow without pressure drop. The force of the differential pressure motivates the air mass. Here is a formula from Norgren Helpful Engineering Information brochure. It is said to be based on the recognized Darcy formula.
Delta P = K Q^2 / 1000 x [14.7 / (14.7 + P psig)] x [(460 + t) /520]
Delta P = psi
Q= Flow in Standard Cubic Feet per Minute (SCFM)
t = Compressed air temperature, (Deg. F)
Values of K per 100 feet of straight, clean schedule 40 pipe size
1/8" = 2300
1/4" = 450
1/2" = 26.4
3/4" = 5.93
1" = 1.66
1 1/4" = .400
1 1/2" = .174
2" = .0467
2 1/2" = .0186
3" = .0060
Good Answers: 119
02/24/2010 4:16 PM
Globalspec to the rescue?
Click Here
Need to have java installed in your browser to run the calculator.
Register to Reply 6 comments
Codemaster (1); DVader1000 (1); Hooker (1); piping_engineer (1); rajindran (1); Tom Kreher (1)
