Previous in Forum: HART Physical Layer Test   Next in Forum: Blast Furnace Camera
Eddy Current Probe Performance
02/23/2010 5:42 AM
Can i use other materials like SS-316, Al instead of 4140 as target material for eddy current probes. What will be the effect on performance of probes by using different material?
Pathfinder Tags: target materail
Re: Eddy current probes performance
02/23/2010 7:06 AM
It can be done but you will have to run a new calibration curve with the new material. With stainless it will change the scale factor (slope of the curve) and it will shorten the linear range. Probably better to buy a probe and proximitor system that is calibrated for your material.
You might be interested in: Electrical Test Probes, CMM Probes, Fiber Optic Probes
