Previous in Forum: Short Circuit / Coordination Study   Next in Forum: Terminal Blocks for Radiant Floors
Transformer Calculations
02/23/2010 4:48 PM
I have the primary and secondary kV, the kVA and the impedance. How would I calculate the X/R? I didn't see the X/R listed on the transformer.
thanks.
Re: Transformer Calculations
02/23/2010 4:49 PM
The primary voltage is 480, secondary is 120. kVA = 15 and Impedance is 4.4%. Sorry forgot to include that.
Regards.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
02/25/2010 10:40 AM
As per IEEE standards and Table No-1.2, X/R ratio=0.867 when %Z=2.7789
In this case, %Z=4.4,
so X/R= 0.867*4.4/2.7789= 1.373
02/24/2010 6:01 AM
Ask Manufacturer-
only he can supply this (else test at your place)
The other option is refer the IEEE std 242 which will give the recommended value of it for different ratings (same as ANSI C57)
And last, most approximate is a thumbrule about 4.9
