Previous in Forum: Rockwell Plant PAx   Next in Forum: Rubber Compound Color Uniformity
18 comments
Fiberglass Insulation
02/23/2010 5:31 PM
can fibreglass insulation blankets be broken down and reused in other applications.
i currently have nearly 100tonnes of fibreglass blankets i am trying to find an alternative use for.
do the chemicals, binders and additives in this material restrict the possibility of breaking it down?
Re: FibreGlass Insulation
02/23/2010 7:10 PM
I don't see why not. How about cutting the blankets into sheets and using them for home insulation, etc. It may be economical to convert the blanket back to fibres (through mechanical not chemical disassembly methods) and re-bind them into another shape.
02/24/2010 1:14 AM
They're already in sheets. They are insulation batts. I want to see if they can be used for something else.
Good Answers: 16
02/23/2010 8:19 PM
Chopped strand FRP?
De gustibus non est dispudandum.
02/24/2010 9:36 AM
Fiberglass is used in the manufacture of gypum drywall. Perhaps contact one, if close enough.
Fiberglass is also used in concrete as reinforcing. You didn't tell us where you are, but mix plants are a lot more common than drywall plants.
Re: Fiberglass Insulation
02/24/2010 10:24 PM
Why not contact the folks at Dow Corning directly, see if they take the stuff back for recycling?
Cheers
Martin
Good Answers: 16
02/24/2010 10:41 PM
I would resell them on local web boards or eBay
Specializing in Dynamic Weighing Systems for Powder and Bulk Solids Handling
02/24/2010 11:25 PM
Hmmm, I can just see the add,,, 220,000lbs of fiberglass pink,, slightly used....
Cheers
Martin
02/24/2010 11:20 PM
Can some of it be donated to Haiti??
Good Answers: 97
02/25/2010 12:38 AM
It's glass fiber, strings of glass and breaks down as glass.
Contact habitat for humanity
02/25/2010 8:46 AM
You can make high end car body and low end sink shower bath tub and hell lot it depend on you interest.
I have used fiber for bath tub and is better and cheaper.
Masyood
Good Answers: 117
02/25/2010 10:21 AM
Are the insulation batts contaminated in any way, say, with asbestos, lead paint chips, water, or mouse droppings? If so, it may be difficult to re-use. Not impossible...I have used it as a filler in fiberglass resin to bulk up the walls of septic tanks and such. If it is clean, of course, the best use for it would be AS insulation. Thats what it is made for after all.
When asbestos is removed from steam pipes in old buildings, it has to be replaced with something, after all.
Good Answers: 42
02/25/2010 11:05 AM
*The dried and set FRP sheets are hard stuff to break.
My idea for reuse of the stuff can be based on the following possibilities..
1] Powder it by grinding and use it as a filling matter in fresh mouldings.
2] By soaking the sheet in the FRP resin solvent system without catalyst and see if gets solublized.
3]Try melt press or Microwave heating for possible fusing down possibility, which can lead to new recycling possibility.
4] Saw tooth based rotor blades can slice down and helpful in fragmentation of FRP moulds, which can be used up for insulative packings.
It all calls for low cost R&D efforts to decide further.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 18
RECYCLING Fiberglass Insulation
02/25/2010 1:31 PM
During our searching for applicable products for a Green-Globes capable school design recently (which may even get a grant to help pay the added costs of getting "LEED" certified), we looked for recycled-content products.
One of the easiest is high-recycled-content fiberglass ceiling panels.
Other recycled fiberglass products are also available, including bulk shredded-fiberglass for insulation.
What you need is to find a large scale collector, or a producer, that can receive or directly use your waste as a feedstock within economical shipping distance for cash or credit toward your purchase of new product.
These two resources assist in getting providers and users to find each other:
http://www.grn.com/a/0955.html
http://www.recycle.net/Glass/fiber/index.html
Try hitting up any applicable entries by others, reading a few of the links, and see if you can find a partner to work with long term - and thanks for doing what you can! Too many give up quickly and dump it, and fiberglass is an energy-intensive product worth recycling, even if it's just to shred it for cleaning, drying, then adding binders and reuse as a bulk insulator.
Call it 'half empty' or 'half full' if you must, I've got the other half in a redundant glass...
Good Answers: 25
02/25/2010 1:35 PM
Not enough info. sorry.
Size: What size are they, and how are they packaged?
Are you just looking for ideas? Or wish to sell them?
If so, how much do you want for them, as a lot?
All these things affect speculation of their possible use.
jt.
They said go for it.. but when I went, it had gone.
02/25/2010 7:12 PM
Thanks for all the replies. Its given me alot of ideas.
To give you more information on the product, it is still in its original packaging.
I am in Sydney Australia. I am trying to sell it back to CHina where i originally bought it from and i am trying to sell on ebay but the market is flooded with this product at the moment so there isnt any buyers.
There is no asbestos in these but the only thing I know is in one batch of these batts is Formaldehyde. About 25% of the total stock.
I am considering breaking it down mechanically but is glass fibre in batts too fine for use.
Cheers
02/25/2010 11:14 PM
From Tim Hawley Master Mech.
Here in Michigan we have companies that have a machine that can shred fine fiberglass and blow it into walls for insulation. Perhaps there is a company there that provides the same service.
Regards,
Tim
02/25/2010 7:55 PM
I believe your fiberglass insulation can be shredded and blown in for new insulation. Sounds like you should invest in one of these shredders, with the material you have you could do a great job in the insulation industry. The shredders are hooked up to a blower with flex pipe to blow the shredded fiberglass into the ceiling cavity. Be sure to wear your respirator when doing this job as the dust count is very high.
05/06/2010 10:43 AM
there is a chemical fix to neutralize the formaldehyde. off hand I cannot remember what it is. I do not think that insulation can be applied legally containing formaldehyde. the fix was an easy one before being placed in homes. more difficult in place. sorry for the late reply. catching up on news, bulletins.
Reply to Forum Thread 18 comments
Anonymous Poster (3); baxterm (2); bwire (1); Delmar (1); diode101 (1); Doorman (1); iyerkumar (1); jack of all trades (1); jt (1); Masyood (1); pretzel (1); s.udhayamarthandan (1); Sandman (1); Tippycanoe (1); Yusef1 (1)
