Previous in Forum: Powder Conveying System   Next in Forum: Calculating GPM Flow When Combining Multiple Sources
HEPA Filters
02/25/2010 2:24 PM
for clean room we use terminal HEPA filter to achieve our classes ( class 100 , 1000 , .............etc. ) and when we make validation for velocity of HEPA filter we use device called rotating vane and when we need to measure flow rate on HEPA filter directly we use device called the hood and i know the relation between velocity and flow rate is ( Q = A* V ) where Q = flow rate , A = area , V = velocity ) but the qty of flow rate for hood is differnt for flow rate for rotating vane and i will give you example for our measuring :-
by rotating vane V = 0.45 m/s and HEPA filter size ( 0.6 m X 0.6 m )so Q= 0.45 X 0.6 X 0.6 = 0.162 m3/sec = 583 m3/hr = 343 cfm
but when i use the hood for the same HEPA filter the reading is approximatelly 200 cfm not 343 cfm
so i want you explain to me which method is right for measuring
thanks
best regards
m. fekry
Location: Western flank of the Pennines in Lancashire England
Re: HEPA Filters
02/26/2010 7:16 AM
The velocity over the face of the filter will vary being higher in the center and lower at the edges. In theory the velocity at the edge of the filter face will be zero, but this is a very narrow area a few molecules wide. If the flow is laminar the velocity profile will be a parabola. If the flow is turbulent and the profile will be flattened in the center. The higher the velocity the flatter the profile. If you have not done an area weighted traverse of the filter face then the calculated value is going to be high.
As the hood gathers all of the air issuing from the filter the velocity through the vane will be higher than a spot reading. This will have 2 advantages over a spot reading. Firstly the accuracy of the rotating vane is likely to be better than at lower flow rates and secondly but more importantly you will be measuring the total airflow. However the extra resistance of the hood and vane will reduce the flow rate slightly so the true flow rate will be less than 343cfm and greater then 200cfm.
This is one of those examples of the process of measurement affecting what is being measured.
Just to prove it to yourself measure the face velocity in the corner of the filter face and compare it to that in the centre. If you are getting 45m/s in the centre with a 100mm dia vane then I would expect the velocity in the corner to be less than 0.08m/s.
Good luck
Re: HEPA Filters
02/26/2010 7:51 AM
When a T&B person measures with a vane, they measure multiple points in a matrix over the surface of the filter. Then they calculate the average velocity. This average will probably be less than 0.45 m/s. Typically the professional T&B person uses a hood because it is more accurate. However, be advised that hoods need to be calibrated every year or so.
R. Turner, P.E.
Register to Reply 2 comments
