Previous in Forum: Fuel Cells   Next in Forum: Building Design for Going Off the Grid
8 comments
MMA and TIG Welder
02/26/2010 1:07 AM
Dear All,
My understanding on power source of MMA and DC o/p TIG is constant current power source. I feel curious whether every MMA machine can do TIG (scratch type) by only changing torch and output polarity. Kindly share the knowledge pls.
Tks and Rgds,
Kotuu2
Re: MMA and TIG welder
02/26/2010 4:03 AM
Which MMA do you mean?
AcronymDefinition
MMAMoney Market Account
MMAMixed Martial Arts
MMAMedicare Prescription Drug, Improvement and Modernization Act
MMAMobile Marketing Association
MMAMetropolitan Museum of Art (New York City, NY, USA)
MMAMinistério do Meio Ambiente (Portuguese: Ministry of Environment; Brazil)
MMAMethyl Methacrylate
MMAMassachusetts Municipal Association
MMAMinnesota Medical Association (Minneapolis, Minnesota)
MMAMIDI Manufacturers Association
MMAMedicare Modernization Act of 2003
MMAMassachusetts Maritime Academy
MMAMaine Maritime Academy (Castine, Maine, USA)
MMAMuttahida Majlis-i-Amal (Pakistan)
MMAMillimeter (Antenna) Array
MMAMulti-Mission Maritime Aircraft (US Navy)
MMAMonorail Manufacturers Association
MMAMarketing Management Association
MMAMennonite Mutual Aid
MMAMaine Municipal Association
MMAMarketing Management Analytics
MMAManual Metal Arc (welding)
MMAMalaysian Medical Association
MMAManitoba Medical Association
MMAMarine Military Academy (private school)
MMAMassachusetts Mortgage Association
MMAMainframe Migration Alliance (Microsoft)
MMAMyanmar Medical Association (Yangon, Myanmar)
MMAMonomethylamine
MMAMutuelles du Mans Assurances (French insurance company)
MMAMedical Marketing Association
MMAMulti-Mission Aircraft
MMAModified Motorcycle Association
MMAMercy Medical Airlift
MMAMeest Milieuvriendelijk Alternatief (Dutch: most environmentally friendly choice)
MMAMicrocomputer Managers Association
MMAManage My Account
MMAMilitary Medical Academy
MMAMassanutten Military Academy (Woodstock, Virginia)
MMAMaria Mitchell Association
MMAModified Motorcycle Association (various states)
MMAMethyl-Malonic Acid
MMAMassachusetts Movers Association
MMAMarine Managed Area
MMAMurtala Muhammed Airport (Nigeria)
MMAMontreal, Maine & Atlantic Railway
MMAMiddle Meningeal Artery
MMAMain Mission Antenna
MMAMaine Military Authority
MMAMaster of Marine Affairs
MMAMulti Managed Account (finance)
MMAMartin Marietta Aggregates
MMAMaine Mycological Association (Bowdoin, Maine)
MMAMulti Media Artist
MMAMaster of Musical Arts
MMAMountain Men Anonymous (band)
MMAMerchant Marine Act of 1936
MMAMennonite Medical Association
MMAMicro Modeling Associates, Inc.
MMAMidwest Mustang Association (Ford Mustang owners group)
MMAMerry Meet Again (Wiccan greeting)
MMAMulti-Modulus Algorithm
MMAMetro Manila Aide (band)
MMAMast Mounted Assembly
MMAMelbourne Metropolitan Area (Australia)
MMAMarked Message Accuracy
MMAMissouri Movers Association Inc.
MMAMy Modern Ad (blog)
MMAMastitis-Metritis-Agalactia Complex
MMAMedical Managers Association
MMAMassachusetts Military Academy (Otis, MA)
MMAMoments Matching Approximation (Algorithm)
MMAMultiplexer Mating Adapter
MMAMedical Materiel Account
MMAMedien Management Akademie GmbH
MMAManagement Accounting and Analysis
MMAMultiple Message Alerting (AT&T)
MMAMajor Mission Area
MMAMaster mind application
MMAMember of the Marketing Association of Australia & New Zealand
MMAMacro Management Scheme (India)
MMAMode-Matching Analysis
MMAMaterial Measurement and Accounting
MMAMaintenance Manual All Levels (TMINS)
MMAMichigan Myomassologist Association
MMAMissile Main Assembly
MMAMudmashers of America
MMAMissouri Midwives Association
MMAMontgomery Modular Arithmetic
MMAMiage Mulhouse Association
MMAMinelayer Auxiliary Ship
02/26/2010 10:14 AM
. It is my weakness. I supposed that MMA welder is enough.
MMA is meant for Manual Metal Arc Welder and TIG for Tungsten Inert Gas Welding.
Would like to express my apology for making you confuse.
Rgds,
Kotuu2
02/26/2010 11:41 AM
No apologies necessary.
Someone more well versed in the welding arts than I would have probably known what you meant.
Back on the farm, we referred to MMA welders as "stick" welders.
I am a casual welder and will not try to give you advice.
Cheers.
Re: MMA and TIG Welder
02/27/2010 8:14 AM
Most of them can, but it is important to use ones with a strike voltage of 60 to 75 volts. Some cheaper low output welders low output voltage,but if you are using a MMA machine with AC/DC volts option it will be more than likely a good quality machine.
02/28/2010 11:04 PM
Dear Garth,
Thanks for your info. Could I take note that strike voltage can be equivalent to open circuit voltage?
Tks and Rgds,
Kotuu2.
03/02/2010 10:31 AM
Yes that would be the case.
03/04/2010 3:20 AM
Dear Garth,
Thanks again for your explanation.
By the way, is there any way to reduce power consumption in normal MMA welder?
I am thinking if a machine can be automatically idle after rest for 15mins during operation and will automatically switch on again after striking frist arc. Is it possible? Pls advice me on this matter.
Thanks,
Kotuu2.
03/04/2010 4:43 AM
In a standard transformer MMA welder the only losses are the magnetising current and heat losses which are not great compared to when you are welding. Apart from fitting capacitors to improve the power factor which will reduce power loss in the lines but would not reduce true power when in use.
You cannot strike an arc if the welder is off, so you would need an auxiliary detection circuit to switch the welder in when trying to start an arc, this could be accomplished with a switch on the welding torch or an electrical detection circuit when the electrode touches the workpiece. But really the complexity would not be justified unless there is a compelling reason.
Register to Reply 8 comments
garth (3); KOTUU2 (3); lyn (2)
