Previous in Forum: Sesamin Extraction   Next in Forum: Sodium Sulphate: Pipeline Corrosion Inhibitor?
Nickel Corrosion and Compatibility in KOH Unit
02/26/2010 10:44 AM
Hi Dears, in our KOH Unit we produce a 90%KOH flakes from 50%KOH liquid through evaporator "tube heat exchanger" then a receiver " drum". the liquid 50%KOH is being heated for 380 deg.C. the problem is we have a corrosion of nickel drum which contaminate the product. i searched in ASME II, i found no data about the minimum strength of Nickel 200/201 above 350 deg.C. Could this be the root cause?? Waiting your reply Kind regards
IF THERE IS A DOUBT, NO DOUBT
Pathfinder Tags: KOH with Nickel
Good Answers: 42
Re: Nickel Corrosion and Compatibility in KOH Unit
02/27/2010 12:56 AM
Think of corrosion inhibitors addition[mild dosage of reducing agents of good temperature resistance[stannous chloride, sodium bisulphite, glucose or glucose substitutes like Hydrol] to the 50%KOH liquor.
Heat, alkalinity, dissolved oxygen with metals-corrosion is unavoidable.
Nature is so graceful and naked. Human possession is ridiculous.
Good Answers: 58
02/27/2010 8:26 AM
Information on corrosion of nickel in caustic potash (KOH)can be found at http://www.specialmetals.com/documents/Nickel%20200%20&%20201.pdf
03/02/2010 6:33 AM
Have a look also at this publications from NIDI
ALLOY SELECTION FOR CAUSTIC SODA SERVICE
http://www.corrosionsource.com/technicallibrary/nidi/literature/pdf/10019.pdf
hope this help u
S
corrosion & rust protection
Register to Reply 3 comments
s.udhayamarthandan (1); strider6 (1); welderman (1)
You might be interested in: Nickel and Nickel Alloys, Drum Pulleys, Drum Heaters
