Previous in Forum: VRV AC Systems   Next in Forum: Valve and Flange Class Parameters
Expanding Tube to Tube Sheet Connections
03/01/2010 5:58 AM
Our standard practice is to first expand the tube in the tubesheet and weld afterwards. This expansion has a rate of only 5%.
Now we have a question from our supplier to first weld and expand the tube afterwards.
We think our own standard is the best procedure because an expansion prior to welding benefits the weldability.
Can anybody give his thoughts about tis issue?
Good Answers: 29
Re: Expanding Tube to Tube Sheet Connections
03/01/2010 8:52 AM
Except for explosive expansion welding, I've never seen it done any other way than expand and weld. I would think expanding after welding would unnecessarily stress the weld. Often expansion is all that is needed for re-tubing condensers where some leakage is acceptable.
Are you re-tubing or sleeving?
Si vis pacem, para bellum
03/01/2010 8:53 AM
- Weld first and expand-
There are possibilities of weld cracking during expansion.
You don't know whether the expansion is done to requirement or not (no testing is possible)
Removal of oil used during expansion difficult (hence weld integrity questionable)
Welding heat may affect expansion.
- Expand first and then weld
No oil so no defects
Tubes may be uniformly welded (maintaining uniform projection)
Weld cracks during expansion
welding may make expansion just a bit difficult (it will affect the tube shape and diameter)
So choice is left to you. Both the methods are used, based on the preferences and the processes developed for the same.
03/01/2010 9:17 AM
Ok thanks for your comments.
Despite the oil issue I think we should go for the expansion and then welding.
Pmoon it is a new exchanger with straight holes and no sleeves.
03/01/2010 11:02 AM
In fact there is another method available- which calls for pre-expand weld and then final expand.
03/01/2010 1:11 PM
Ah yes, the old expand-weld/weld-expand arguement
It always makes for a good discussion/heated battle.
The answer is - it depends.
One thing I will mention that has not been mentioned above is - there is a risk you can loose the seal from expanding first, then welding because of thermal expansion/yielding at temperature.
This discussion can lead the "chicken and egg" rhetoric.
Ask 5 different people this question and you will get 6 different answers.
Anonymous Poster (3); PMoon (1); Siesling (1)
