Previous in Forum: PLC Fault Mode   Next in Forum: Wireless Trigger Transmission
Network Equipment
03/02/2010 10:48 PM
What is the difference between router & switch & hub
Location: West Point, Texas population around 200.Located between Austin and Houston
Re: general
03/02/2010 11:51 PM
Switch works OFF/ON??
router,"Where do you want to go today?"
Joe in Texas
We hold these truths to be self evident,one nation under God
Re: general
03/03/2010 3:21 AM
A hub broadcasts all input received out to all connected paths without regard to best path or equipment identity.
A router uses a table of device and destination information to select the best path to forward an electronic info 'packet' it receives. Usually is associated with or an integrated part of a gateway device or switch.
As you might imagine, one is better at conservation of resources and tracking packets.
For switches, see answer #1.
I do not 'know it all', but i will admit that I would like to. CJM
