Previous in Forum: Excess Flow Valve for LPG Truck   Next in Forum: Run-Out Criterion
12 comments
Good Answers: 143
Measurement Error
03/03/2010 8:34 AM
This is a take-off from the discussions in the Weight Lifter Challenge blog, but I'd like to start a discussion devoted to a practical way to understand measurement error. I think I generally understand the subject, but I can't explain it clearly and sometimes I don't know which way to use it. So, let me propose an example, and please tell me if I'm seeing this wrong or too simple or too complicated.
Suppose I want to measure the length of a piece of metal along an edge. I have a machinist's scale which is marked in cm and ruled to 0.5 mm, so each cm has 20 divisions. The scale is made by a well-respected company and I have checked the overall accuracy and found it to be good within at least 0.02 mm.
So, I think the scale has no systematic error of any significance since I know enough to avoid parallax errors. So, the error of measurement will come from the resolution of the scale and my ability to distinguish between divisions.
I measure the edge and find it to lie between 111 mm and 112 mm. In fact, I think I can tell that the edge length is nearer the middle of the division than either line, so I write down 111.5 mm. Now, I understand the 0.5 mm to be uncertain, so I could leave it that way, or I could make an estimate of my uncertainty and write 111.5 mm +/- 0.2 mm.
I understand this to be a worse case error, and I think it is limited by the resolution of the scale. Even if I get a loupe, I don't think I can do much better.
So far, how am I doing? Have I made any stupid assumptions? Have I made any mistakes?
Good Answers: 29
Re: Measurement Error
03/03/2010 9:08 AM
It is generally accepted that any scale; linear, dial, or other, can be read to the nearest one half of the smallest division of the scale. In your example; divisions of one half millimeter (0.5 mm) can be read accurately to the nearest one quarter millimeter (0.25). The accuracy of the measuring device is usually specified by standard as a percent full scale, such as in ASME hydrostatic testing "the accuracy of the pressure gauge shall be 0.5% minimum of full scale." Therefore; the accuracy of the measuring device is not generally included in the reported measurement.
Back to your measurement; if you observe that the edge length is closer to 111.5 mm than to half way between, then you report that measurement as 111.5 mm. If your observation is that the measurement is closer to half way to the next increment then you should report that as 111.75mm. If it is closer to the next division on the scale than the half way point, then it would be recorded as 112.0 mm even if it is actually less than 112.0 mm.
I haven't read all the discussions on the challenge question, so I don't know if this helps solve your problem, but I am sure there will be lots of disagreement on this thread.
Si vis pacem, para bellum
Good Answers: 143
03/03/2010 9:20 AM
Yes, thank you. I wrote that incorrectly didn't I? I'll copy it here and fix my boneheaded mistake.
I measure the edge and find it to lie between 111.5 mm and 112.0 mm. In fact, I think I can tell that the edge length is nearer the middle of the division than either line, so I write down 111.7 mm. Now, I understand the 0.7 mm to be uncertain, so I could leave it that way, or I could make an estimate of my uncertainty and write 111.7 mm +/- 0.2 mm. I could have written this as 111.8 mm and I could have estimated my uncertainty slightly differently. But I chose 111.7 mm +/- 0.2 mm. I think I cannot write 111.75 mm since I don't have the ability to resolve 0.05 mm.
So far, how am I doing? Have I made any stupid assumptions? Have I made any (more) mistakes?
Good Answers: 29
03/03/2010 10:17 AM
I'll clarify my mistake. If the required accuracy is 0.25 mm, then you can use the scale you have. Remember you can measure accurately to the nearest one half division. It would be incorrect to record the measurement to the nearest tenth because your accuracy is 0.25 mm. You can only take measurements of 0.25, and 0.5 beyond the last whole mm. If your divisions were in 0.2 mm, the it would be acceptable to record measurements of 0.1, 0.3, 0.5...etc.
If you round the measurement to the next tenth beyond 0.25 or 0.75, and the measurement is used in a calculation later, then you will begin what is known as propagation of error. Measure and record only to the nearest one half division of the scale on your measuring device. If you require more accuracy in you measurement, use a scale with smaller divisions.
All of the above has nothing to with the overall accuracy of your scale. It is only about the accuracy of your measurement and how you record it.
Good Answers: 143
03/03/2010 12:28 PM
Thanks. Let me explain that I'm not being difficult, but I have to explain this to someone who is, and I'm trying to make sure I can justify everything I normally do (and in the process of asking you guys, I hope to fill in some of the gaps in what I know), so please don't mind if I question closely.
So, since I have no appreciable systematic error, my error is presumably a random one, which could be improved by multiple trials and statistics. But, here I have only one measurement, so I'm treating my best estimate of the reading as though it were the mean and I'm treating my best estimate of the uncertainty as though it were the standard error. Is that right?
My second question is in these odd number cases. I see that, if I have a scale marked in 1 mm increments, that my uncertainty might, by rule, be +/- 0.5 mm. But, in this case, I deliberately chose 0.5 mm divisions because I don't know how to justify using either +/- 0.25 mm or +/- 0.3 mm for the uncertainty.
I'm not asking about a guard digit that I would need for subsequent calculations; I'm trying to treat this as a single measurement that will never go into any calculation. I guess I could handle the idea of +/- 1/4 mm (groan), but I'm suspicious of saying +/- 0.25 mm. My suspicion may just be a residue of my drafting days when half of 0.25" was either 0.12" or 0.13" depending on which rule I was following for that job.
03/03/2010 12:46 PM
if I have a scale marked in 1 mm increments, that my uncertainty might, by rule, be ±0.5 mm
Not necessarily. See the next post the ILE and uncertainty are two different things.
ILE depends on the spacing between the markings (0.5mm) and then the error in the markings (0.02mm)
Let me just enlarge the view assume that the markings are in 10cm (least count), the errors in marking is 1mm
Then reasonably say you will be able to read (or interpolate) 2 cm ? (visually/ with whatever instrument you have)
So the possible error in the estimate will be this 2 cm along with the 1 mm for the marking error.
In other example, take a spring balance, marked in Kgs but the gap between markings is say 2 cm. Accuracy of markings is 0.05 Kg, so with all reasonableness you should be able to measure even 0.25kg on the scale, that will be compounded with the other uncertainty 0.05Kg in marking itself.
03/03/2010 11:19 AM
The measurement terminology
a) Least count - the smallest division on the scale - that is 0.50 here.
b) Instrument Limit of Error- That is the value that can be read by interpolating the gap between the minimum division. Of course it depends on the
- spacing between division
- The measurerer's comprehension/ eyesight (missing the exact term)
- usage of additional instruments
etc.
For an example, for an electronic load cell of 3000 Kg the Least count we have asked is 1 Kg
The Error (repeatability, accuracy etc all included) is 0.24 Kg - and no it is not an error it is peermitted in class A instruments (there was a controversy on exact this point)
This is digital, then how do you check the accuracy and repeatability < LC ?
Simple - use of additional instrument - use a volt meter with required accuracy to read the signal directly before it is fed to ADC circuit.
The ILE is always equal or less than the LC now for your case it can be as low as 0.02 (you may always use a microscope you know)
So it all depends.
End of the day you have to go to statistics and do GR&R
Good Answers: 143
03/03/2010 12:57 PM
Do most people really do GR & R for a length measurement? That seems like a lot of effort and time? Is there a sort of "quick and dirty" GR & R?
03/03/2010 9:08 PM
Theoritically yes, practically - no.
Finally it depends on your activity- what you are trying to measure and with what accuracy.
For an example- Digital verniers have a LC of 0.01mm. You try to use that and you have to do GR&R
However we have a thumbrule- any tolerance tighter than about ±0.03 go for micrometer.
Tighter than ±0.01 - either GR&R or multiperson+multi instrument measurement.
It all depends on - how you can make your life just a bit more complicated simple.
However all the automatics are regularly calibrated for the above, including the machines and gauges (even non-fully automatic ones) of labs.
Good Answers: 143
03/04/2010 8:06 AM
Thanks. I believe I understood everything you said even though I didn't know it. But, could I ever explain that to a potential client (who I can't even get to calibrate his %%$# DMMs!)?
Here's my fundamental dilemma. I think I'm a professional. That means I would never do structural steel design for a 10 story building because I simply don't have the experience. But, I know enough about it (I'm pretty sure I can do a 2 story building) that I could explain to someone why it's important to hire a structural guy to do this. And, I think I can explain the transitions between the single steel beam in my basement all the way up to the Sears Tower (Whatever it is now).
But, I don't have that confidence and knowledge when it comes to measurement. I can usually make a single measurement and get it right (quite likely with too large an error because I'm playing it safe), and I can do the statistics on 1000 trials and get that right. But, I couldn't explain to someone when they should hire a QA or metrology guy to do, say, 3 measurements. And, I don't know how to tell them why they need a professional.
03/04/2010 9:16 AM
You know (well I am a QA/metrology/...guy) so it does not look nice for me to say ,
But we do too much of window dressing (if you get what I mean ) may be to keep my place firm.
A lot of exercise - of common sense - is done to prove something that is not necessary in the first place. Call it lean, 6 sigma, 5S, GR&R ...
It is 80% commonsense in the core covered well by the nice clothes and given a name. may be the steps of the way to achieve the common sense are written down.
may be in the prehistoric time the humans would have written down - take two dry piece of wood, colelct some dry grass twigs, collect all the clan to watch and protect from air, rub the wood... (fire making procedure)
But unfortunately they didn't have the written language.
How many bridges or surveys are done with the instruments that has passed the GR&R ?
Of course if you do GR&R you can put that into your web-page (and the customers who don't understand or might have heard the name) will flock to you then you can fleece them .
Well we have made (and make) gas Turbines without it on measuring instruments. But again note the CNC machines that we have are calibrated for the GRR as well as the CMMs but then exccept the real critical few none use that feature/machine/CMM isn't it?
Last word is what the end result demands, whether this can be achieved in a simple way or not. Why to complicate the issue when it is really simple ?
Good Answers: 143
03/04/2010 9:31 AM
I hope I'm not making it complicated. If it's simple, tell me how to state the uncertainty, precision, and accuracy of three voltage measurements made by the same person using the same meter. Keep in mind that I have to then explain this to a pedantic, arrogant PhD who is literally the perfect storm of ADD and OCD. I'm sorely tempted to throw my hands in the air and say, "Stick this project where the sun don't shine!", but I need the work right now (tough times in Pittsburgh).
03/04/2010 12:13 PM
Let us go to the basics,
When we do any measurement, two types of errors can take place,
systematic error- controllable in the sense that certain steps can eliminate these errors. These are usually attributable to man, machine method etc (the Ishikawa/ Fish bone diagrams)
The method to control these are the operator training/calibration, instrument calibration, standardizing method of measurement, working the AC, 20oC room,...
Usually these errors give rise to shift in one side (hence also called bias) say you are in Washingtom DC and hence at 0oC so all your readings are likely to be less than the actual reading (job is less size than the actual), or the operator who always presses the thimble a bit too tight, or the instrument has a bias (zero error) ...
Though this bias is not necessary , but you will see a pattern in the bias for these errors.
Systematic error is related to Accuracy -
Accuracy means the relationship between the actual value and the measured value. So if you use a NIST calibrated slip gauge and micrometer reads 10.03 whereas the actual is 10.00 then your measurement accuracy is 0.03mm.
Random/ Nonsystematic/Indeterminate Errors- these are due to indeterminate root cause and hence can not be avoided. You measure the slip by same micrometer in the same condition (AC temperature&humidity controlled metrology lab) 10 times and you will get 10 different readings reason of variation? unknown. This variation is expressed as the uncertainty of measurement - converting into the standard deviation.
This has got nothing to do with the actual value for 10.00 slip, your readings may vary between 10.01 to 10.07, the average 10.03 (this 10.03-10.00 is the bias)
but even if you remove it the variation will remain.
This variation or the uncertainty has nothing to do with actual value - it is the part of precision, ie with what degree of precision you can tell the value. So unlike the common misconception - precision is not with how many places of decimal you are measuring - rather how close to each other your values are. eg
10.1, 10.2, 10.1,10.1 is more precise than (variation 0.1)
10.0999, 10.2150, 10.0885, 10.0597 (variation = 0.155)
or 10,11,10,10 (variation 1)
So the precision, let us talk in terms of range here (since you are having only reading) is the value between largest and smallest.
Accuracy = actual - average
Precision is technically same as the uncertainty for a set of readings
For a single reading - the number of decimal places will be the precision.
I just saw a good one here look at the bull's eye.
Register to Reply 12 comments
Anonymous Poster (5); PMoon (2); TVP45 (5)
