Previous in Forum: Powder Coating Spray Guns   Next in Forum: MDF Polyster Coating
Engineering Fields - Energy Engineering - Any good anergy saving toys out there?
Andon Radio Data Capture
02/01/2007 12:49 PM
Hi
I just got hired as a Co-op student at a manufacturing company called Navistar where transporter trucks are assembled, http://chtsvw08.cht.navistar.com/ this is the link to it. Being new to the company and the manufacturing process I noticed several issues with the way the parts are handled at the workstation. After talking to my supervisor and discussing the 5 year improvement plan I decided to work on Andon communication system which will eliminate the shortages and get the assembly process up to speed.
There are several companies such as: http://www.oeeimpact.co.uk/ , http://www.andonsystems.co.uk/menu_key.htm that can help find the solutions to the communication problems found on the floor. Only those companies sell their ideas above the normal cost of $6500 pounds. The actual components cost that take to setup the system and the software that should only be around $2000. Cost is the reason why I am trying to investigate a cheaper and more flexible approach.
I guess my question would be addressed to all the networking and software development engineers, and anyone that is interested in researching the interfacing subject of everyday industrial automation. The problems I'm facing are:
1. The components used to make the output device and how the signal can be transmitted with the use of buttons.(Transmitter)
2. Interface the output signal to the computer. What would be the best receiver? (receiver connected to the computer)
3. Automatic log of data into the spreadsheet. What program would be best to transform the data into readable format such as Excel, and if it possible just to input data into Excel spreadsheet without any use of other programs. (Program that can log the info.)
Abstract
The worker at the workstation informs the floor supervisor through radio of a part shortage. The signal is stored in the program. The call is answered and the problem is taken care of in the prioritized manner, depending on its magnitude. The signal is stored for analysis and reviewed for later improvements.
Thanks for any help and advices. Appreciate everyone's time.
Tim
you can do it if you put your thought into it....
Re: Andon Radio Data Capture
02/02/2007 7:26 AM
You should be aware that there is more in that cost than just the components. I would expect that they would install whatever you purchased and also provide support during a warrenty period.
If you are looking for a work report topic, which I think is likely, identifying the needs of the plant and specing the components is sufficient. If Navistar is saying "too expensive!" and is expecting you to build something in house, then you need to make it clear that you are not going to be around to support this system.
