In ASME B31.1,under fabrication and erection chapter it had shown that if internal mis-alignment of pipe is more 2 mm then ,pipe has trimmed inside.
My doubt is that, internal mis-alignment can be taken same as inside thickness difference of pipe.
or
Internal mis-alignment and inside thickness difference of pipe both are different concept.
Explain difference in above both concept.
