Previous in Forum: Slider Crank Mechanism Variations   Next in Forum: Wheel Unbalance
Calculating Air Consumption
02/01/2007 7:15 PM
If we say a person have a air compressor of 605.2 CFM rated as free flow with a motor of 90 KW 188psi . asked for calculating the efficiency of the compressor with 200 of pneumatic on/off valve , 100 of control valve etc . What is the thumb rule to calculate the efficiency of the compressor.
Kiran.
Re: Calculating Air Consumption
02/03/2007 5:12 AM
The equations for calculation are given below
Compressor Efficiency Definitions
Several different measures of compressor efficiency are commonly used: volumetric efficiency, adiabatic efficiency, isothermal efficiency and mechanical efficiency.
Adiabatic and isothermal efficiencies are computed as the isothermal or adiabatic power divided by the actual power consumption. The figure obtained indicates the overall efficiency of compressor and drive motor.
Isothermal Efficiency
Isothermal power(kW) = P1 x Q1 x loger/36.7
P1 = Absolute intake pressure kg/ cm2
Q1 = Free air delivered m3/hr.
r = Pressure ratio P2/P1
The calculation of isothermal power does not include power needed to overcome friction and generally gives an efficiency that is lower than adiabatic efficiency. The reported value of efficiency is normally the isothermal efficiency. This is an important consideration when selecting compressors based on reported values of efficiency.
Volumetric Efficiency
Compressor Displacement = P x D2 x L x S x c x n
D = Cylinder bore, metre
L = Cylinder stroke, metre
S = Compressor speed rpm
c = 1 for single acting and
2 for double acting cylinders
n = No. of cylinders
02/03/2007 12:20 PM
To some extent you need to decide what the 'efficiency' figure is needed for.
GUEST has given an exact formula but with so many other factors involved that it makes an accurate figure almost impossible because a lot of the factors are based on assumptions. Your flow of 605.2 cfm quoted to one decimal place is suspicious to say the least.
If it is 'rule-of-thumb' you want, then an approximation should do. Everything else being made equal, the power required in terms of your working pressure will be proportional to loge r (see Guest formula) where r is the pressure ratio - which is your delivery pressure divided by your atmospheric pressure (absolute).
for other calcs first you need to establish the accuracy of the numbers you insert in your formula - use those given by the compressor people
Then go to this link and read about how careful you must be when using the result of these 'accurate' figures.
http://www.cashflo.co.uk/Calc.html
You can then investigate the steps you must take to get nearer the efficiency you want for your own application.
Good Answers: 137
02/05/2007 4:18 AM
Guest's formula in #1 is correct in some circs but not for most practical cases. What's needed is the polytropic power, given by
(P1 x Q1)/n*((P2/P1)n-1) watt in SI units, m3/sec and Pa. The "polytropic exponent" n = 0.23. This is the power needed to compress the air and comes to 104 kW. To calculate the compressor shaft power need to divide by compressor efficiency, could be 65% but supplier can confirm. Gives ~160 kW. 90 kW motor is too small.
Isothermal power comes to just over 75 kW so even in this case with typical compressor efficiency 90 kW motor is inadequate.
02/05/2007 10:09 AM
Re Codemaster detailed reply.
The conclusion that 90 kw is not big enough for 605.2 cfm, prompts one to ask what the output would be from a compressor fitted with a 90kw motor.
On a polytropic basis at 65% efficiency (typical and realistic) you get 340 cfm whereas on a an isothermal basis at 100% efficiency (highly unlikely) you get 726 cfm.
This does not answer the original question but it at least point to the things to look out for, and it all depends on the actual design of the compressor.
You would have to carry out actual tests in order to accurately compare compressors. And if you want to introduce some degree of consistency into your study you might find this standard useful:-
ISO 1217 - Displacement compressors -- Acceptance tests.
This will not solve your problem about the amount of air needed to operate your equipment. But at least it will remove a lot of guesswork when selecting the right compressor.
At the moment the sums suggest a compressor with a 90kw motor will not be big enough to run your equipment - if 605 cfm is the amount of air you want.
Anonymous Poster (1); Codemaster (1); horace40 (2)
