Previous in Forum: 1991 Ford Pickup - Water from Tailpipe   Next in Forum: 1998 Ford Escort - Transmission Slipping
14 comments
Oil Levels and Motor Noise in 6-Cycle 2005 Ram 1500
03/10/2010 11:14 AM
How can I fix this noise. when I start my Ram 1500 year 2005,the motor sounds like no oil on it,but after 10 seconds the noise disappear and the motor works very smooth...
Best Regards.
Re: ram 1500 6cyl year2005
03/10/2010 11:31 AM
Ummmmmm...
What does the oil dipstick say? If it says "Oil Level Low", then add some.
More information might get you better answers...
03/10/2010 11:56 AM
Yea!!! I thought so and I already did but the stick says is OK on leveling place.
Thank you!!!
03/10/2010 11:55 AM
You don't tell us how many miles are on the vehicle and if this is a new noise? You don't tell us how the vehicle has been maintained (regular oil changes, etc.)
My advice: Turn up the radio.
If the vehicle has more than 100,000 miles on it this is not unusual. It, also is not a cause for alarm.
Keep on truckin'.
03/10/2010 12:00 PM
Well Yes I perform regular oil changes and I only use for NO load ,I only Load with my 20kgs, natural gas tank.Miles just 45000.
03/10/2010 12:03 PM
Hey there Lyn.
"My advice: Turn up the radio." LOL!
Man, I wish I would have asked for advice about my old Ford Econoline before I spent $400 on parts. That trick would have saved me a bundle!
err... is it OK to call you man?
03/10/2010 12:33 PM
Dude, I once worked with a person who asked me to look at her vehicle because the AC was blowing hot air. When I looked under the hood, it was obvious that the compressor had locked up and the belt eventually burned up and fell off the car.
When I asked her how she could possibly have not heard such a terrible noise, her response was, "Oh, I heard it, I just turned up the radio". (She was serious!)
03/10/2010 12:57 PM
So you have met my family?
It drives me nuts how some people treat their equipment and then wonder why it does not work properly.
Zero maintenance means zero operating cost. If you never fix anything it never costs you anything to operate it. Dont use it because it doesn't work properly but dont fix it because it doesn't get used enough to justify it. If it was fixed it would get used more but then it would also need more maintenance which would cost more.
03/10/2010 1:46 PM
This kind of stuff is too funny! And, at the same time sad. People (other people, not CR4 members) seem to exist at arms length with an understanding of any type of machine, equipment, tool...
My aunt had a (I think) Toyota Corolla (older car, no troubles; in fact, a pretty good car) and the 'Check Engine' lamp came on. A true mystery. After consulting with a number of her friends, they decided the car was sick, it had a boo-boo. So, as with any boo-boo they have ever encountered, simply placed an elastic bandage over the lamp. Out of sight, out of mind, I think she said. Eventually, the lamp went out (burned out), and she was convinced it was 'all better'.
As a preemptive answer to the next question: about 4 months. Main Bearing (as I recall) first, this was ignored (probably turned up the radio!), then the crankshaft gave out! Broke! Kaput! Blooey!
03/10/2010 2:01 PM
OK, I just have to ask. When you took the picture that is now your avatar, did you point the camera directly at her chest, or did you take her face too and crop it?
03/10/2010 2:17 PM
"...or did you take her face too..."
Why would I have done that?
Oh, yeah. Now I remember. This is why:
OH NO!
post script to Guest OP: This sort of hijack just happens sometimes. If you need some more help, chime in and we will try.
03/10/2010 5:36 PM
"So you have met my family?" You're not alone. If it goes forward and isn't on fire, it's OK to drive.
Good Answers: 29
03/10/2010 11:59 AM
Most wear damage to oil lubricated machinery occurs at start up. When all of the lubrication has settled in the sump (oil pan) and only a thin film if any remains on the moving parts. Once things get going and the oil gets up to pressure and finds its way through all the passages to the moving parts everything literally runs smooth.
There are aftermarket electric oil pumps that can be purchased from J.C. Whitney (and others) that will begin circulating oil prior to starting, and all but eliminate that wear and in your case the noise (most likely).
Si vis pacem, para bellum
Re: Oil Levels and Motor Noise in 6-Cycle 2005 Ram 1500
03/10/2010 7:11 PM
Do you live in a cold place?
Humm... suspicious you are...
03/13/2010 4:17 PM
Could you give us some more info such as, What engine do you have in the vehicle, is it a diesel or do you mean a 6 cylinder? Did you recently change the oil and use an off the wall oil filter which may not have an anti-drain back valve in it?
Anonymous Poster (1); bhrescobar (1); Doorman (4); fjmartineze (2); lyn (4); PMoon (1); tcmtech (1)
You might be interested in: Noise Standards, RF Noise Meters
