Previous in Forum: What's the Highest Temperature?   Next in Forum: Plastic-Encapsulated Glass
9 comments
Turbine Lube Oil
03/11/2010 10:44 PM
We are using "Shell AeroSHell Turbine Oil 560" for our LM 6000 machine.
Recently we sent a sample of the Lube oil for testing.
Very high contents of Sodium were found in the sample,
3 samples were sent periodically
76ppm..........98ppm...........84ppm
We are using De-min water in our Turbine lube oil heat exchangers, therefore Sodium will not contaminate the oil if there is a leakage of Demin water in to the lube oil.
What is the reason behind the high Sodium content in the lubricating oil...?
Re: Turbine Lube Oil
03/11/2010 10:47 PM
03/12/2010 1:55 AM
In the samples you gave for testing, have you also given a sample of brand new, un-used oil? Is it completely sodium free? If it is, then the answer is simple. Wherever your lube oil circulates, there is a sodium containing contaminant. Shouldn't be too difficult to find what it is.
03/15/2010 7:35 AM
We've sent a sample of the fresh oil as well.
Waiting for the results.............................
03/13/2010 2:42 AM
Check your de-min water composition carefully. May have very minimum unnoticed sodium, and very fine leaks of water vapors to lube oil and final form sodium.
03/13/2010 6:22 AM
Vipy,
Tell the mechanics to keep their potato chips out of the shop!
Luther M
There are old pilots and there are bold pilots, but there are no old bold pilots.
03/14/2010 12:08 AM
Is your gas turbine situated in a coastal location?
03/14/2010 12:20 PM
Yes, our main cooling water intake is from the Arabian sea.
But as I mentioned earlier, we are using De-min water for our internal cooling circuit.
03/14/2010 8:18 PM
I am not very familiar witht LM6000, but would suggest that if you are not gertting this from your cooling water you are probably contaminating your oil via the atmosphere in which you are working. Check the purging of oil sump, demister if fitted, bearing purges/buffer gas etc. Special attention to the air compressor bearings. You suck in that amount of sea air and get these things wrong you get salt in oil.
03/15/2010 3:50 AM
It can be that the sodium is used as an additive in lubricant to make a protective layer over the metals in the engine.
Do to the extreem heat of the engines combustion the oil evapotates and the sodium is left behind as a layer on the matel. This layer will protect the matels against the high tempertures.
Register to Reply 9 comments
Anonymous Poster (3); JanJansen (1); Loki (1); Luther M (1); lyn (1); vipy (2)
