i've got a 94 toyota 4x4 (22re automatic) that has developed a stutter (hesitation) off idle. from a cold start, everything is fine with no stutter. however, if the engine is shut off before coming up completely to operating temp and restarted, it develops the hesitation. it seems like it's getting flooded out - too much fuel and not enough air. i've replaced the o2 sensor, checked the choke, checked the fuel injectors, vacuum lines, etc. and found nothing. it doesn't throw a code - no check engine light. any ideas? btw, motor has 165k with no other issues.
