Previous in Forum: Converting DC to Sine Wave   Next in Forum: Power factor in residential systems
Re polarizing ceramic magnets.
03/12/2010 8:13 PM
This may be an easy one for the right person but for me up to this point I have yet to ever do it on purpose.
Can the ceramic magnets in servo motors be re polarized, have their polar orientations moved, simply by brute force from a stronger electromagnetic field?
Reason being I have a large DC servo motor I would like to change from an 8 pole to a 4 pole. The ceramic magnets that make up the 8 poles are four single ceramic magnets with both poles on the face. I want to re polarize them to be one pole on each face.
My thoughts are to turn the end bell that the brushes are mounted on to the correct spot that puts the rotor is in a magnetic stall then rewire the brushes for the four pole configuration and then just hit each pole with a several hundred amps from my DC welder a few times to force one of the poles on face of each magnet to change its polarity so that each magnet has only one large pole facing the rotor and not two smaller poles.
Will this work or will I be more likely to have the rotors intense magnetic field just rip the ceramic magnets off the outer frame? The rotor windings and stators are robustly built so they can take several hundred amps for a short time with out damage. My concern is that the ceramic magnets may either pull off or not fully re polarize and I will end up with a junk motor.
Any thoughts on how servo motors get their magnets re energized while being refurbished and can that method also be used to change how the magnets pole orientations are setting as well?
Good Answers: 141
Re: Re polarizing ceramic magnets.
03/17/2010 9:54 PM
It is possible to re- magnetize your magnets. We did that many years ago a lot with high power acoustic speakers. Ferrite looses strenght more than e.g alnico, but the latter has restrictions to use. Can You remove them out of the motor and take them apart? Your welder - if DC output is available - can be your current supplier. You will need to make a coil and put the magnets through the center opening. The ends become your N and S pole - ferrite is to magnetize either way. We needed doughnut shape ring magnets magnetized on the smallest side - the thickness. Be careful, and check the polarity of your welder. The cleanest way is to demagnetise them first, if you do not want to go for the full remanence. Otherwise into saturation when the sizes and composition are the same. They need to warm up with your current. Too much current can even crack some ferrites. If broken, you can glue them back together with epoxy. Make sure everything is clear around. and fix the magnets well. Time and current depends on the size of magnet
Plenty of room here
