I have an issue with a TWIN DISC Marine Gear Box in a very remote island location. When shifting it to forward it doesn't transmit the engine power to the propeller. I tried to service it and only at the dock with low rev's it pushes the boat forward in that position.
Once in the open power lacks completely. I wanted to know how the gearbox works.
Asked for a drawing but the manufacturer doesn't answer my mails. Last time when the oil has been replaced, the old oil was smelly (burnt?) and black. The gearbox weighs about 100 kg (220 lbs). I guess the couple transformer is burnt?
Does someone have a drawing? Need the discs replaced? Can I overhaul them without
replacing? Is it possible to repair this gearbox in the boat - because the mounting pads of the engine are also attached to it. Taking out the gearbox is a lot of extra job.
(supporting the engine underneath - handling the weight and more)
I did repairs like this before on ZF gearboxes from the end towards the engine, keeping the gearbox housing on the spot. But then I had a drawing and instructions. Plus the concept of the gearbox allowed this. The oil pump pressure seems ok and the position lever also.
