Previous in Forum: Motor Windings and Inferred Temperature for Zero Resistance   Next in Forum: Electrical Equipment Damaged by Lightning Strike
Underground Cable Sizes
03/15/2010 11:32 PM
I am looking for cable sizing calculation and name of vendor for under ground cable which can serve in area having condition as:
1. Voltage grade: 10 kV
2. Ambient temp: (-) 28 deg C to +46 deg C
3. Frosting/Icing during winter: up to 500 mm below grade.
4. Length of cable: up to 4 km or long.
5. Cable size: up to 70 mm2, 3C.
Any web link for sample calculation (cable sizing) will be very helpful.
Pathfinder Tags: cable sizing
India - Member - New Member Hobbies - Model Rocketry - New Member Hobbies - HAM Radio - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Control Engineering - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member
Re: Under Ground Cable
03/16/2010 3:13 AM
Hi shock007, I dont know about the vendores, but here are some hints on how to calculate the sizes.
1. Get the length of supply, maximum allowable drop and current/power demand figures.
2. From the cable vendor's datasheet calculate voltage drop of cable as per the cable length and current you are drawing from that cable. Start with the lowest size satisfying the the current/power demands (to minimize cost). The first one that satisfies is your answer!
3. Increase number of runs (resulting in the reduced capacity of power needed per cable run) if the size goes out of your limits.
And do take care for the derating factor and power factors in your calculation. Also consider the reduction in current carrying capacity with ageing..
Hope it helps
03/16/2010 3:51 AM
try nexan, pirelli........google can give more results
03/16/2010 2:52 PM
Most cable manufacturers that sell MV or HV energy, utility, transmission (etc) cables will have something suitable in their product range.
Also try Generalcable (New Zealand), Olex, Amercable (USA), Gaoncable (Korea), etc (you do not say which country you are in but most have branches around the world).
Good Answers: 141
Re: Underground Cable Sizes
03/17/2010 12:32 AM
where are you located shock?
Plenty of room here
03/17/2010 7:30 PM
This is for a project in Turkmenistan.
03/17/2010 7:31 PM
03/17/2010 1:58 PM
Try Anixter in the USA
Register to Reply 7 comments
Anonymous Poster (2); dvmdsc (1); jack of all trades (1); krahul (1); shock007 (2)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
