Previous in Forum: Industrial Wiring - New Developments?   Next in Forum: How to Analyze Electrical Load Data
Generator Voltage and Excitation
03/16/2010 12:53 PM
why the generator can not produce 11kv voltage after giveing sufficient excation. can u clear my doubt what happen in generator after get excation? because the 11kv is not produced in my set. It will up to 6kv only comes.
Re: Generator Voltage and Excitation
03/19/2010 1:33 AM
because :
- lack of magnetic flux Φ , remember : Ea = c.n.Φ
- on brush-less generator :
. is the excitation voltage optimal (excitation voltmeter = rated value?) if not,
may be 2 or more rectifier diodes break-down
03/19/2010 3:20 PM
if diode break down how voltages is build up.
but excation voltage is normal
03/28/2010 6:29 PM
Check rotating diodes, this will limit voltage output by reducing field voltage
03/19/2010 3:25 PM
but excation voltage is normal.
Anonymous Poster (1); harnoko (1); sats (2)
