Previous in Forum: Calculating RPM and Torque for DC Motors   Next in Forum: High-Altitude Adjustments for Appliances
Auto Feed to Spring Cable
03/17/2010 1:53 AM
I would like to give the auto feed to the spring cable (Linear movement), The spring is rotating with the help of "engage & disengaging of 3 jaws", the jaws gets rotary motion by the gear which runs by a electric motor.
a mechanism is required, once the jaws disengages the spring cable, mechanism or device should make it possible to move the spring cable linearly.
FYI: The spring cable we are using inside the drain line for cleaning purpose.
Good Answers: 37
Re: Auto Feed to Spring Cable
03/18/2010 8:36 AM
Second set of jaws and drive mechanism, in line with first but spaced some distance apart, plus leadscrew to move one of them at a time? Engage first set, turn cable while moving second set to rear-most position; engage second jaws, then disengage first set (cable can continue turning). Now move first set rearward and repeat cycle. Reverse sequence for pulling cable back out after cleaning. Using a dual leadscrew with one right-hand and one left-hand thread for the motion would permit pushing or pulling the cable during rotation (dual leadscrews are used in devices needing equal travel of paired objects, such as grippers or end effectors, and some precision machines already).
" Ignorance and arrogance have more in common than their last four letters. "
05/22/2010 12:49 AM
Thank you sir
You might be interested in: Chuck Jaws, Vise Jaws, Cable Laying Services
