Previous in Forum: Food Processing Plants vs. Pharmaceutical Plants   Next in Forum: Lithium Ion Polymer Battery Manufacturing Process
Weld Crack in SS 316L Sheet
03/17/2010 6:54 AM
Dear,
I made a potable water tank with S.S 316L 3mm sheet.In that some are getting crack on its belly position exactly on its heat zone(Just above the welding)I used 316l electrode and I feel that my procedure is correct and same as earlier.How it si happening?.Any material problem or welding error?Kindly Advise?
Good Answers: 58
Re: Weld Crack in SS 316L Sheet
03/18/2010 8:56 AM
If you have observed all metallurgical precautions (and it sounds like you have), and are still getting cracks, I suggest preheating the weld area. This will reduce the stress during cooling.
03/18/2010 3:39 PM
What welding process are you using, and have you confirmed the grade of your stainless steel and filler metal? At time we have ran into problems such as yours, and investigations normally find that we have overlooked something. The last problem we had with stainless had to do with the so called same grade from 2 different suppliers. It turns out that it was not a mis-labled item, one was just of poorer quality.
Good Answers: 58
03/18/2010 11:09 PM
You might also try filling the tank with shielding gas while welding.
Register to Reply 3 comments
