Previous in Forum: Compressor Shaft Power Vs. Actual Compressor Hp Rquirements   Next in Forum: Fuel Efficient Tyres
Seamless Square Tube
02/05/2007 7:17 PM
Is it possible to get a seamless square tube of material ASTM A-500 grade C?
thanks
Re: seamless square tube
02/06/2007 8:23 AM
You could conform a blanket using the same technology used to obtain round seamless tubes, with some problems in the corners to be solved with the process development. Maybe a variable geometry cross section in the blanket should be used, there are going to be many heat treatments in the way, but, why do you need that ? Isn't there a simpler and cheaper way of doing the same thing?
Humm... suspicious you are...
Good Answers: 27
Re: Seamless Square Tube
02/06/2007 11:17 AM
Looks like it is. A quick search on "seamless steel tubing" resulted in a number of suppliers in North America and International; primarily China.
02/07/2007 2:14 AM
Thank you. May i know whare are your location addrest. Are you fabricator company ? This is exotic material and need to special order direct to mill. How many pieces your requested, Length, product flow and deliver to what country ?
I try to help you settle this issue.
ZUL
06/26/2008 3:46 PM
By strict definition, seamless tubes cannot conform to A500, which is a cold formed welded tube spec.
More applicable would be the spec ASTM A501, which is a hot formed spec. Seamless squares can be made either cold drawn (A519) or hot finished (A501).
Vallourec & Mannesmann (V&M) can produce yield strengths that exceed grade C. 65,000 yield, even 70,000 yield are easily produced.
Min quantities are 5 or 10 metric tons per size, (11,000# or 22,000#) depending on the size.
Lead times are 3-4 months
Anonymous Poster (2); bhrescobar (1); Bluestone (1)
