Previous in Forum: Adhesive Joints and Nano-Enhanced Glues   Next in Forum: Coloring Stainless Steel
Windmill Furling Diagram
03/23/2010 7:25 AM
I have recently begun making a windmill and was going to use the dimensions at "http://www.thebackshed.com/windmill/Docs/Furling.asp" but recently when I went back the site was unavailable. Would anyone have a saved copy of that web page or diagrams
Pathfinder Tags: windmill design
Good Answers: 213
Re: Windmill Furling Diagram
03/23/2010 11:46 PM
I just checked- the site is back up and the document is available on line. There is a bit of an explanation as to why the site went down in the forum pages. If you try again and can not access the document, send me a private message with your e-mail, and I will forward a copy to you.
03/24/2010 7:53 AM
Thanks for that cwarner7. I managed to get the web page. As to be expected I just finished cutting out the mounting plate from memory. I may have to make a few adjustments now.
Good Answers: 22
03/25/2010 5:47 AM
By the way, in general when this happens, you can often use a Google or Bing cache to get the info you need, or if it disappeared a while ago and there is no longer a valid search result, you might find it on the WayBackMachine - which caches web pages as a historical record - http://www.archive.org/web/web.php
(I think there are other such databases around too.)
Glad you found it in this case.
Register to Reply 3 comments
cwarner7_11 (1); mortal (1); RobertOz (1)
