Previous in Forum: Pump Data sheet   Next in Forum: Manufacturers of Mincer Plates
Adhesive Tapes for Bonding Vinyl Membranes
03/23/2010 9:37 AM
Adhesive tape for bonding textile reinforced fabric with transparent vinyl membrane.
Just starting a new project that involves production of PVC roll up blinds.
I know how to heat weld and HF weld PVC membrane but understand it may also be possible to use heat or pressure activated double sided adhesive tape. Tape requirement is to bond a transparent PVC vinyl window membrane to a textile reinforced PVC surround (25mm overlap) . Must be transparetn, anti-aging, reasonably UV resistant and hopefully cost effective for series production.
Any ideas or recommendations appreciated.
Re: Adhesive tapes for bonding vinyl membrane
03/23/2010 9:47 AM
You should contact suppliers directly, especially if you will be using lots of their product.
I've used a number of products from:
3M United States: Industrial Adhesives, specialty adhesives ...
with much success. Not an endorsement of 3M, just my experience.
