Previous in Forum: Factors Affecting Op Amp Gain (Closed Loop)   Next in Forum: Aluminum Cables
Turkey - Member - New Member
Ground Loop
03/23/2010 11:43 AM
http://www2.mdanderson.org/depts/cpm/standards/details/ee-260526-01.pdf
take a look at this and tell me pls what does" ground loop" mean here? ground loop is a case not a real loop made by a conductor as seen here isnt it? so what does this mean in fact?
jinxnao
Good Answers: 29
Re: Ground loop??
03/23/2010 11:54 AM
A common ground throughout all the systems of your cancer center.
Re: Ground loop??
03/23/2010 11:57 AM
Re: Ground loop??
03/23/2010 12:01 PM
http://www.uic.edu/depts/accc/telecom/Tedpics/TEDS07.JPG
it is something like this? it is kinda loop isnt it? if not so why do we call it as" ground loop" ?
as you see here in a loop there is no chance of "ground loop" problem , so is this scheme what we apply to telecom rooms? please
jinxnao
Re: Ground loop??
03/23/2010 12:01 PM
Read This http://en.wikipedia.org/wiki/Ground_loop_(electricity). The note "ground loop" conductors in this drawing is not what we normally refer to as the ground loops due to improperly installed conductors. This installation is just the grounding electrode conductors installed in a loop to decrease the impedance of the grounding system. This is a very common installation.
Re: Ground loop??
03/24/2010 5:13 AM
to make a IT grounding conductor a loop and connect the devices' grounding conductors to this loop impedes the" ground loops faults "?
jinxnao
Re: Ground loop??
03/23/2010 12:35 PM
"Ground loop??" Is what you don't want to do in your tail dragger!
Register to Reply 6 comments
Anonymous Poster (1); jinxnao (2); lyn (1); RDGRNR (1); wareagle (1)
