I am in the process of designing industrial control systems that require intercommunication between them. Because of certain requirement, I need a fast link with a high degree of data integrity but the amount of data transmitted between systems is not large, about 10 bytes. I would use RS485, half-duplex wire as the physical link. All this is basically a given and fixed. All I need to know is if I would require to do "bit stuffing" on the data as to prevent the line "seeing" more than 4 consecutive "0" or 4 consecutive "1". The references I can find only refers to "bit stuffing" in order for synchronization between receiver and transmitter. Because RS485 is an asynchronous bit stuffing is not required. What are your view points?
