Previous in Forum: Both Generators Trip While Running in Parallel   Next in Forum: Vertical Mounted Wind Turbine Needed
Dough Mixer Motor
03/26/2010 4:32 AM
I have a dough mixer. The motor slows down on load. The brushes are fine and the commutators is ok too. What could be the problem?
Good Answers: 29
Re: Dough Mixer Motor
03/26/2010 8:33 AM
Not enough water?
Good Answers: 143
03/26/2010 8:45 AM
Either the water mentioned above or else too small a motor for the load. I used to use commercial dough mixers to mix epoxy and found that it was cheaper to buy the biggest honking motor I could find.
03/26/2010 9:06 AM
Did it just start doing this after previously running properly? Did something in the process change that would cause an overload?
Check the amperage draw of the motor When it is slowing down. Are all three legs (if it is three phase) roughly equal? How does it compare to the stated FLA of the motor.
Are any of the stator windings showing too little resistance?
I would also check to see that the input voltage is as expected. If it is three phase they should all be about the same. Sometimes there are problems with the supply voltage.
If this checks correct I suspect there is a mechanical problem as mentioned. Such as the mixer is being overloaded or it is too small.
Everything I know about opera I learned from Bugs Bunny
03/26/2010 7:33 PM
If is a Hobart M-802 or a V-1401 ... your clutch disks are worn and need to be replaced....if it is Univex.... probably a glazed drive belt..... The make and model information is needed to give you any assistance at all.... also as noted previously... if it is not 3 phase..it is not a "work horse"... "Brushes" indicates a DC drive motor to me....... More information needed.........
Engineering Fields - Electrical Engineering - New Member India - Member - New Member
03/27/2010 1:22 AM
Dear ,
Please check the DC motor specifications, is the duty cycle/overload cycle matching the load. probably as the dough thickens and becomes more viscous, the shaft may not be able to provide the requisite torque.
Thanking you
Anonymous Poster (1); DaveB (1); RDGRNR (1); shanbhag (1); TVP45 (1)
