Previous in Forum: Vertical Mounted Wind Turbine Needed   Next in Forum: IEC CYLINDERICAL FUSE
NER-NGR
03/26/2010 7:24 AM
IN SOME OF THE DRAWING SHOWS NER SOME OF THE DRAWING SAY NGR BOTH OR CORRECT OR IF ANY TECHNICAL CLARIFICATION ?
Re: NER-NGR
03/26/2010 8:05 AM
nEutral earhing resistor and grounding resistor?
guest
Good Answers: 244
Re: NER-NGR
03/26/2010 8:51 AM
Earthing (European) = Grounding (North American)
NER - Neutral Earthing Resistor (European) = NGR – Neutral Grounding Resistor (North American)
Based on you location, find which one applies to your drawing and correct accordingly.
- MS
Register to Reply 2 comments
