Previous in Forum: Hydralics used in Fire Fighting applications   Next in Forum: Pressure Vessel
welding
03/27/2010 9:33 AM
is it necessary to pre and post heat pipes before welding?
Re: welding
03/27/2010 9:51 AM
depending on material and thickness. But is is rare under normal circumstances. Except some rare occasions, no preheating has ever been necessiated in my career. And post heating - unlss you call burning the pipes in furnace to remove the residues before solvent clean/pickling as post heat, never.
Good Answers: 243
Re: welding
03/27/2010 10:31 AM
Presuming you are talking about steel pipes.
http://pmpaspeakingofprecision.com/2009/12/29/carbon-equivalent-and-weldability/
milo
Good Answers: 58
Re: welding
03/28/2010 2:45 PM
It depends upon the alloy of the pipe, and the temperature of the site. They had to preheat the Alaska pipeline to get the metal to a safe welding temp. If a weld cools too quickly, it could crack. A post heat would allow the stresses to relax in a more uniform nature. Soft metals don't care too much, hard, or brittle metals, like cast iron, require a lot of experienced technique.
mike k
Register to Reply 3 comments
Anonymous Poster (1); mike k (1); Milo (1)
