Previous in Forum: Difference Seriel and parallel interface   Next in Forum: Mininizing the Damping Factor of 3051 Series Rosemount Pressure Sensors
NACE Requirement
03/28/2010 10:26 PM
Hi,
NACE Certification for material is required when Process fluid contains sulfur or it is corrosive in nature. But i don't know how much sulfur amount is required in process so i can tag it with NACE Requirement ? Please let me know a minimum amount of sulfur in fluid for which NACE is must.
Regards,
Re: NACE Requirement
03/28/2010 11:32 PM
The Jamesbury document here:
http://info2.jamesbury.com/requests/download/downloaddoc.aspx?docid=T101-4
goes through an example of determining the mol%H2S. Good reading!
03/29/2010 2:25 AM
Hi Carl E,
Thanks ... Informative document....
03/29/2010 1:54 AM
"NACE Requirement" is too vague.
As per NACE MR0103-2007:
1.3.5.1 Some environmental conditions known to cause SSC are those containing an aqueous phase and:
(a) >50 ppmw total sulfide content in the aqueous phase; or
(b) 1 ppmw total sulfide content in the aqueous phase and pH <4; or
(c) 1 ppmw total sulfide content and 20 ppmw free cyanide in the aqueous phase, and pH >7.6;
(d) > 0.3 kPa absolute (0.05 psia) partial pressure H2S in the gas phase associated with the aqueous phase of a process.
1.3.5.1.1 The high-pH sour environments differentiate refinery sour service from the oil and gas production sour environments covered by NACE MR0175/ISO 15156, because many wet sour streams in production also contain carbon dioxide and hence exhibit a lower pH. Another major difference is that chloride ion concentrations tend to be significantly lower in refinery sour services than in oil production sour services.
Register to Reply 3 comments
Anonymous Poster (1); Carl_E (1); Tazzy (1)
