Previous in Forum: Well Pump - Spring Startup   Next in Forum: Best Aluminum Tube Shape Design for No Sag
9 comments
SS Hard Surfacing
03/29/2010 7:34 PM
Have any of you heard of using SS for hard surfacing?
Re: hard surfacing
03/29/2010 7:36 PM
Re: SS Hard Surfacing
03/29/2010 9:59 PM
Stelliting is for one.
03/29/2010 10:30 PM
elaborate please?
Fans of Old Computers - Commodore 64 - Commodore Vic 20 Australia - Member - New Member
03/30/2010 2:05 AM
Are you referring to Stellite ( I think that's how it's spelt). A brand of hardfacing and building up materials of different types.
One in the Stellite range from memory does have a Stainless like deposit. But I think they are more into the cobalt-chrome type of wear materials not the Austenitic type.
See: http://www.stellite.com/
I like deadlines, I like the swooshing sound they make as they fly pass - Douglas Adams
Good Answers: 141
03/29/2010 10:21 PM
SS is not that hard, - need Cr, Mo, e.g. -alloys
Plenty of room here
03/29/2010 10:28 PM
will it "work harden"
Good Answers: 141
03/30/2010 2:23 AM
George, what is the hardness you have in mind and for what purpose you need to use it? Stainless steel has no good running qualities unless in rubber bearings and water or oil lubricated. Of course when applied to a soft material, even plastics it is "harder", but compared to the "cemented" and polished coatings on e.g. crankshafts, it stands no chance. For axial gliding you can apply it. Some pistons for heavy equipment have that kind of coating. But the strongest and real heavy duty ones have different alloys as surface.
Plenty of room here
Good Answers: 141
03/30/2010 2:31 AM
Found this link. Maybe of some use. http://www.engineersedge.com/stainless_steel.htm
Plenty of room here
03/30/2010 1:59 AM
Yeap, a couple of times mostly in situations where proper Austenitic Stainless Steels Rods/wire wasn't available (in the middle of the bush in the middle of no where encourages invention).
I seen 309 work harden up to 65Rc, if done properly it would go higher.
Mostly use in applications where there is some metal to metal sliding like wear.
If you can have a good look at AS/NZS 2576: 1315-A4 prefectly acceptable Stainless (like) deposit
Side Note: It's always done with a buffer layer of E7018 or E8018-B2 underneath though.
Register to Reply 9 comments
Anonymous Poster (1); dvmdsc (3); lyn (1); ozarcgeorge (2); ozone88 (2)
