Previous in Forum: Activity Based Costing (ABC)   Next in Forum: Welded Pipe and Maximum Resistance
Effect of Rotary Swaging on Hardness
03/30/2010 1:52 AM
Dear All,
I would like to know what is the effect of rotary swaging on the hardness of the swaged portion of the pipe. And if the swaged end of the pipe does get hardened then by approximately how much?
Thanking you..
Regards,
Sahil
Re: Effect of Rotary Swaging on Hardness
03/30/2010 12:15 PM
I'm not 100% sure, but I think the end of the pipe get softer, remember your cold forming the pipe, and by it getting softer it forms a better seal with the mating part.
but let's see what others say.
Good Answers: 243
03/30/2010 10:00 PM
Rotary swaging cold works the metal, so hardness will increase in proportion to the % of cold work.
Given the proper strain hardening coefficient for the material and the amount of cold working strain fromswaging, this can be calculated. Here is a link:
http://en.wikipedia.org/wiki/Strain_hardening_exponent
milo "rubbing seldom makes things softer"
03/31/2010 2:29 AM
but then how to get the strength coefficient K?
i would rotary swage an alloy steel pipe of grade ASTM A335 P9. pipe has to be reduced from O.D.50mmx5mmthk to O.D.44mm and approx length to be swaged is 8 inches. how do i work out the increase in hardness in this case?
-sahil
04/12/2010 3:51 AM
Dear Sahil,
Please check the hardness of your work and refer chart for the strength. In case of carbon steel, there is direct relationship between hardness and strength. Also, Cracks developed due to work hardening should be checked before applying work loads.
Regards.
Ram
Register to Reply 4 comments
Labyguy (1); Milo (1); rssahni (1); Sahil (1)
