Previous in Forum: Preheating Biogas (Methane)   Next in Forum: UV-Cured Elastomer Material
Blank Stage (Centrifugal Pump)
03/30/2010 8:30 PM
API 610-2003
5.1.6
Pumps shall be capable of at least a 5 % head increase at rated conditions by replacement of the impeller(s) with one(s) of larger diameter or different hydraulic design, variable-speed capability or use of a blank stage.
So what does "blank stage" mean here?
I am not a home work cheater. I am a translator seeking professional help
Good Answers: 27
Re: Blank Stage (Centrifugal Pump)
03/30/2010 10:36 PM
The API is referring to a multistage pump with one stage a "blank" stage. This means that an extra stage is provided for in the original design, but with no impeller installed. You can then satisfy the requirements of this clause by installing an impeller into that stage at a later date.
For a pump with many stages it may be that increasing the casing size to allow for larger impellers at a later stage is not feasible or cost effective, and a blank stage becomes the best alternative.
I have no special talent. I am only passionately curious. Albert E
03/31/2010 12:48 AM
sounds good to me.
Register to Reply 2 comments
You might be interested in: Blank ID Cards, Stage Lamps, Centrifugal Pumps
