Previous in Forum: Global McMaster   Next in Forum: dc brushless motor
Rail Wheel contact surface hardness
02/07/2007 10:50 AM
I am designing a structure that are to be travelling on rail. I manage to get the wheel size right and now are looking into the material specification. Can anyone advice me on is there any requirement on surface hardness of the wheel?
say my wheel material have a ultimate tensile stress of 650MPa, can I based on that to find a equivalent hardness? or I should size up another factor?
It would be good if anyone can advice me some website/book regarding wheel contact surface hardness specification.
Thanks in advance
Zichau
Pathfinder Tags: wheel rail contact hardness
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
Re: Rail Wheel contact surface hardness
02/07/2007 11:41 PM
Both Wheels and rail are prone to cracking if not fabbed properly. Hard wheels on hard rail are good for low friction, but not for power transfer. Soft rail head peens, Hard wheels at constant speed develop corrugations from harmonics. Bumpy rail rides destroy ties. Many more wheels are replaced than rail sections, but rail sections are much more expensive to replace. The system runs while you replace wheels on several out-of-service pieces, but rail replacement at best slows the whole system down to a crawl.
Now, what was the question?
RichH
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
Good Answers: 137
02/08/2007 4:17 AM
Good summary, I enjoyed that!
02/08/2007 2:58 PM
Me too.
Thanks.
02/08/2007 3:13 PM
As a first approximation may be you see or study FEM standards.
Good luck!
02/08/2007 4:27 PM
Depends on the load you're moving, and how far it is going. You want the component that is most easily replaced to be less hard, so that the other component experiences negligible wear. In the case of a railroad line, you have many miles of rails spread over a very large area. You would then make the rails harder than the wheels so that you can just replace/recut/rebuild the wheels when they are worn.
If you have a short rail system going from one side of a room to the other, it might make sense to use harder wheels and replace 8 to 12 foot rail sections when it becomes necessary.
Anonymous Poster (2); Codemaster (1); CoolHandGene (1); NoSciFi (1)
You might be interested in: Hardness Testers, Diamond Tools and Wheel Dressers
