Previous in Forum: One question on Design for Realibility   Next in Forum: Coating / Painting
8 comments
OD to Thread check
03/31/2010 3:43 PM
What equipment/method will check the Threads to another outer diameter on the same part?
Re: OD to Thread check
03/31/2010 3:47 PM
Maybe an optical comparator.
But I don't understand the question.
03/31/2010 3:53 PM
Print call out is 'runout .0015 from the pitch of a thread to an OD' on the same part
03/31/2010 4:02 PM
So, this implies that the two features are on the same centerline.
Put in lathe, true up, rotate and measure runout with a dial indicator.
Or #1.
Or?
03/31/2010 4:35 PM
How would that work - only would be checking the OD of the thread to the other OD on the same part.
03/31/2010 6:11 PM
Never mind. You don't understand runout. It can be done statically and dynamically.
04/01/2010 7:50 AM
Actually I don't think you understand. It is the crown of the pitch diameter not the OD or ID that the callout is refering too. In otherwords, checking the pitch diameter of the thread to another OD or ID. It in no way is the same, even though it might be turned at the same time. FYI - QA usually does not usually have a lathe to check part(s) with.
04/01/2010 8:03 AM
Good luck.
03/31/2010 4:22 PM
You will need a thread gage made for this. the gage will screw onto the part and then tram (measure) the o.d. (outside diameter) of the gage while having the part sitting in a vee block on the datum diameter.
the gage needs to be made where the pitch diameter of the id threads are less than .00015" runout with the O.D.
Questions?
Register to Reply 8 comments
gerrywatts (3); Labyguy (1); lyn (4)
