Previous in Forum: Formulae Dealing with Inertial Force   Next in Forum: 2000 Chevy Cavalier Problem
9 comments
Which Tool to Tighten CV Joint Boot Bands?
04/01/2010 4:49 PM
Which tool is used to tighten CV boot band such as those used on EMPI or GKN boots? These bands have a rectangular hump on the back close to its end and are held in position by a lip of metal on the inside of the band close to the end of the that slips into one of multiple rectangular holes that have been stamped into the band. Confusingly, the EMPI catalog refers to these as 7mm wide "ear" bands.
I assumed that http://www.amazon.com/Empi-W0133-1643984-EMP-EMPI-Boot-Clamp/dp/B001HLXFHG was an "ear" band.
Which tool do I use to tighten the clamp with the hump and the rectangular holes?
A) Lisle 30800 http://www.amazon.com/gp/product/images/B0002SREPY/ref=dp_image_0?ie=UTF8&n=15684181&s=automotive
or
B) Lisle 30500 http://www.amazon.com/gp/product/images/B0002SREB8/ref=dp_image_text_0?ie=UTF8&n=15684181&s=automotive?
Advice from those who have removed and reinstalled these bands would be appreciated.
Pathfinder Tags: CV boot band CV joint
Re: Which Tool to Tighten CV Joint Boot Bands?
04/01/2010 5:24 PM
Hey there DennisWaller.
If I take your first link, and go about half way down the page, I find this tool
http://www.amazon.com/Lisle-30950-Constant-Velocity-Banding/dp/B0002SRCZQ/ref=pd_bxgy_auto_text_c
recommended for the clamp (I presume it to be a use two or three times tool). It appears the two you link to are also appropriate, but more robust, more expensive.
04/01/2010 5:33 PM
Here is a picture of the CV band I have
http://forums.audiworld.com/picture.php?albumid=130811&pictureid=211466
Dennis Waller
Hobbies - Car Customizing - New Member
Good Answers: 11
04/01/2010 11:03 PM
Lisle 30800 cv boot pliers
Good Answers: 60
04/02/2010 4:59 PM
Ah Ha that type.
Sorry you cant tighthen then, you cut them off and replace them.
Good Answers: 60
04/02/2010 5:30 PM
you could use thin jubilee clips
http://www.jubileeclips.co.uk/
http://www.google.co.uk/products?oe=&q=large+jubilee+clips&lnk=qsugb&ei=V2G2S_fgM4Gz-Ab3zYDABg&sa=X&ved=0CEAQhggoAA
don't worry about balance the shafts rotate relatively slowly compared to wheels
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
04/02/2010 6:02 PM
I'm curious about the comment, "the shafts rotate relatively slowly compared to wheels".
The angular velocity is the same for the wheel and shaft. The linear velocity, a function of the angular velocity and radius under analysis, can be different, but the angular velocity will not, assuming a typical half shaft from transaxle to hub (1 to 1 relationship).
Speak softly and carry a big stick.
Good Answers: 50
04/01/2010 11:02 PM
The Lisle 30800. I have one that's over 20 years old. Used it many times years ago and it's what you need for the type of band you're working on.
As a sdie note, any particular reason you're booting joints? Got away from that near the end of my mechanic career when complete driveshafts became so cheap. Perhaps you're working on a special application.
04/02/2010 7:44 AM
Hi DennisWaller,
Just a suggestion: which I've used a number of times, with perfectly acceptable results. Why don't you just use cable/zip ties?
Good Answers: 50
04/02/2010 5:56 PM
Let me clarify some details. If you are installing new CV bands as you've illustrated, you should use the Lisle tool whose part number I noted.
Other tools will distort and/or damage the band beyond use. I have straightened used bands in the past many years ago on a few occasions, but that did not usually work. On occasion it did, but not often.
I have used cable ties; the issue here is many are not heat rated sufficiently high to use without premature failure from heat related stress.
Use a new band, tighten with the tool I noted. You'll get the best results.
Register to Reply 9 comments
Anonymous Poster (1); DennisWaller (1); Doorman (1); peterg7lyq (2); standarded (3); Yosemit3 (1)
You might be interested in: Switch Boots, NVRAM, Linear Actuators
